5085e rear SCV making excessive noise - they say it is normal???
   / 5085e rear SCV making excessive noise - they say it is normal??? #11
On the new tractor that the dealer says is normal, I would get some proof of those statements just in case. I once had a dealer deny we had a couple of conversations on a vehicle that later turned into a problem that he was fully aware of. Bothered me enough to switch to Toyota.
I have an earlier model of a similar tractor and found that the SCV valves stuck just a little bit one time. Caused funny things to happen including my brakes to fade/fail and the pedal to go to the floor when hot.
   / 5085e rear SCV making excessive noise - they say it is normal??? #12
Mine does it ...
I'm thinking about changing the filter this week and seeing if that does something ...l.
Did you change the filter ?
   / 5085e rear SCV making excessive noise - they say it is normal??? #13
Changed it today and topped it off with about 2 gallons of fluid (sight glass said it was a little low).
So far it SEEMS like the SCV is quieter with another implement. I havnt had the batwing on it yet, which was the implement that would make the snap/crackle/pop sounds when I was raising the deck.
482 (A52708)
482 (A52708)
HAND WINCH (A58374)
HAND WINCH (A58374)
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58214)
2014 MAGNUM...
2017 Ford F-550 (A55973)
2017 Ford F-550...
set of 4 tractor trailer tires Roadforce (A56435)
set of 4 tractor...
2017 Gravely Pro-Turn 460 60in Zero Turn Commercial Mower (A55973)
2017 Gravely...
