5085e rear SCV making excessive noise - they say it is normal???
   / 5085e rear SCV making excessive noise - they say it is normal??? #11
On the new tractor that the dealer says is normal, I would get some proof of those statements just in case. I once had a dealer deny we had a couple of conversations on a vehicle that later turned into a problem that he was fully aware of. Bothered me enough to switch to Toyota.
I have an earlier model of a similar tractor and found that the SCV valves stuck just a little bit one time. Caused funny things to happen including my brakes to fade/fail and the pedal to go to the floor when hot.
   / 5085e rear SCV making excessive noise - they say it is normal??? #12
Mine does it ...
I'm thinking about changing the filter this week and seeing if that does something ...l.
Did you change the filter ?
   / 5085e rear SCV making excessive noise - they say it is normal??? #13
Changed it today and topped it off with about 2 gallons of fluid (sight glass said it was a little low).
So far it SEEMS like the SCV is quieter with another implement. I havnt had the batwing on it yet, which was the implement that would make the snap/crackle/pop sounds when I was raising the deck.
20FT X 12FT LIVESTOCK SHELTER (A58214)
20FT X 12FT...
NEW IDEA AVCO 1R CORN PICKER (A52708)
NEW IDEA AVCO 1R...
Case-IH 4 Cylinder Power Unit (A57149)
Case-IH 4 Cylinder...
JOHN DEERE 12' BOX SCRAPE (A52708)
JOHN DEERE 12' BOX...
BUSH & BOG 16 BLADE DISC HARROW (A52708)
BUSH & BOG 16...
Swict 66" Bucket (A57149)
Swict 66" Bucket...
