5085e rear SCV making excessive noise - they say it is normal???
   / 5085e rear SCV making excessive noise - they say it is normal??? #11
On the new tractor that the dealer says is normal, I would get some proof of those statements just in case. I once had a dealer deny we had a couple of conversations on a vehicle that later turned into a problem that he was fully aware of. Bothered me enough to switch to Toyota.
I have an earlier model of a similar tractor and found that the SCV valves stuck just a little bit one time. Caused funny things to happen including my brakes to fade/fail and the pedal to go to the floor when hot.
   / 5085e rear SCV making excessive noise - they say it is normal??? #12
Mine does it ...
I'm thinking about changing the filter this week and seeing if that does something ...l.
Did you change the filter ?
   / 5085e rear SCV making excessive noise - they say it is normal??? #13
Changed it today and topped it off with about 2 gallons of fluid (sight glass said it was a little low).
So far it SEEMS like the SCV is quieter with another implement. I havnt had the batwing on it yet, which was the implement that would make the snap/crackle/pop sounds when I was raising the deck.
2019 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2019 MQ POWER...
SCALES & PEA (A58374)
Mini Skid-Steer Forks (New/Unused) (A59225)
Mini Skid-Steer...
2012 International 4300 Reefer Truck (A56435)
2012 International...
2008 MACK CHU613 TRI AXLE 16FT DUMP TRUCK (A58018)
2008 MACK CHU613...
Kubota B21 (A57148)
Kubota B21 (A57148)
