5085e questions
   / 5085e questions #1
sacarmic
Deere 5085e, 3320
So I am getting loose on a 5085e (upgrading from a 5303). Still haven't decided between cab and open air. I do have a couple of questions.
Is the DEF only on the 15+ models? The 13 & 14 still have the exhaust filters though, correct? How often do you change/clean?
On the cab model is there any upgrade to put 3pt high arms lift controls on the back fender? I know the M series has then. I haven't seen it on the E series, but there is a knock out hole on their fenders where it might go.
Thanks,
Scott
   / 5085e questions #2
Haven't looked at the E and M series that closely but they might use the same fenders. To get the rear hitch controls would require that you have electric/hydraulic control valves. Not as simple as just adding a switch.
   / 5085e questions
Also has anyone installed rear work lights on this unit? IS the wiring already there to run my own lights or do I need their kit? IT looks ike it just come with the lights and wire pigtails to attach them.
Thanks Scott
   / 5085e questions #4
Thanks Scott
The wiring is in place for the work lights but you still have to add the switch to the console. I added work lights to my cab using the Deere kit simple install as I recall.
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55314)
2022 John Deere...
2018 Ram 3500 4x4 Service/Utility Truck, VIN # 3C7WRTCL0JG387527 (A57453)
2018 Ram 3500 4x4...
Dayton 32965 80-Gallon Horizontal Air Compressor, 22 Volts, 5 HP, 2 Stage, 3 Phase (A59076)
Dayton 32965...
2015 TROXELL 130BBL STEEL (A58214)
2015 TROXELL...
2013 BMW 328i Sedan (A55853)
2013 BMW 328i...
1997 Ford F-450 Flatbed Truck, VIN # 1FDLF47F6VEB26852 (A57453)
1997 Ford F-450...
