3-Point Hitch 5030 nh 3pt hitch not working pto turning
   / 5030 nh 3pt hitch not working pto turning #1
j george
new holland 5030
3pt hitch not lifting and the pto turning out of gear.Pull aux and the lift lifts very slow.
Lift lever seem to be sponge.Pull the top and see nothing broken. Replaced the o ring on the acutator large piston. Anybody know where problem maybe.
New member here. Like the forums
   / 5030 nh 3pt hitch not working pto turning #2
The pto clutch plates are probably dragging a little. they probably won't transmit any torque but will cause the shaft to rotate.
Is the fluid at the required level? Any water in it? How many hours since you changed the hydraulic filter? Is the pump making a screaming noise (air entrainment)?
   / 5030 nh 3pt hitch not working pto turning #3
If the tractor hydraulic fluid has water and it has frozen that can cause the lack of lift on the 3pt. Some of the NH models have brakes on pto, check the NH web site for your model and see if brake is listed.
fuid level correct, no water new fluid just changed it and filters, no pump noise
new fluid no water, no presure at brake to hold pto
Sundowner Rancher Express 20FT Livestock Trailer (A56435)
Sundowner Rancher...
2019 CATERPILLAR 305E2 CR EXCAVATOR (A52709)
2019 CATERPILLAR...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
2017 Chevrolet Silverado 2500 4x4 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
