3-Point Hitch 5030 nh 3pt hitch not working pto turning
   / 5030 nh 3pt hitch not working pto turning #1
j george
new holland 5030
3pt hitch not lifting and the pto turning out of gear.Pull aux and the lift lifts very slow.
Lift lever seem to be sponge.Pull the top and see nothing broken. Replaced the o ring on the acutator large piston. Anybody know where problem maybe.
New member here. Like the forums
   / 5030 nh 3pt hitch not working pto turning #2
The pto clutch plates are probably dragging a little. they probably won't transmit any torque but will cause the shaft to rotate.
Is the fluid at the required level? Any water in it? How many hours since you changed the hydraulic filter? Is the pump making a screaming noise (air entrainment)?
   / 5030 nh 3pt hitch not working pto turning #3
If the tractor hydraulic fluid has water and it has frozen that can cause the lack of lift on the 3pt. Some of the NH models have brakes on pto, check the NH web site for your model and see if brake is listed.
fuid level correct, no water new fluid just changed it and filters, no pump noise
new fluid no water, no presure at brake to hold pto
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A56859)
2004 Fleetwood...
16ft T/A Flatbed Trailer (A55758)
16ft T/A Flatbed...
2007 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A58214)
2007 INTERNATIONAL...
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
23105 (A56859)
23105 (A56859)
2020 Freightliner Derrick Digger Truck (A55973)
2020 Freightliner...
