3-Point Hitch 5030 nh 3pt hitch not working pto turning
   / 5030 nh 3pt hitch not working pto turning #1
j george
new holland 5030
3pt hitch not lifting and the pto turning out of gear.Pull aux and the lift lifts very slow.
Lift lever seem to be sponge.Pull the top and see nothing broken. Replaced the o ring on the acutator large piston. Anybody know where problem maybe.
New member here. Like the forums
   / 5030 nh 3pt hitch not working pto turning #2
The pto clutch plates are probably dragging a little. they probably won't transmit any torque but will cause the shaft to rotate.
Is the fluid at the required level? Any water in it? How many hours since you changed the hydraulic filter? Is the pump making a screaming noise (air entrainment)?
   / 5030 nh 3pt hitch not working pto turning #3
If the tractor hydraulic fluid has water and it has frozen that can cause the lack of lift on the 3pt. Some of the NH models have brakes on pto, check the NH web site for your model and see if brake is listed.
fuid level correct, no water new fluid just changed it and filters, no pump noise
new fluid no water, no presure at brake to hold pto
2019 Harley Davidson (A56859)
2019 Harley...
2025 Mahindra 6075 4WD Cab Tractor - 71 HP, Loader Ready, Ag Tires (A55315)
2025 Mahindra 6075...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
Alligator Statue (A55853)
Alligator Statue...
2016 Ford Edge SUV (A56859)
2016 Ford Edge SUV...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A55315)
2023 Kubota...
