MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 58,104
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Its only flat on the bottom.
Can't tell from that picture I posted, but these forks tend to BEND in an arc several inches in front of where they are attached to the mounting plate, not at the joint.
They were only $250 from the factory and have been one of my most used tools, and I'll be the first to admit I abused them for things they are not intended to do.
If I were to build my own forks.... I wouldn't! I'd go to one of several used forklift dealers near here and pick up a set of used forks and adapt mounting to my machine. Unless I got the steel for real cheap, it would be much cheaper and a better use of my time than reinventing the wheel.![]()
I was kinda planning on doing them on the short side so that they'd be tough to bend. Main reason would be lifting logs and moving waste to burn piles.... What's the reason for wanting them so long?
Nope. In straight lifts of too heavy of a weight, the rear of the tractor just comes off the ground. What bends them is getting them wedged in something (the ground, a stump, etc...) and then operating the dump/curl function.That's a great deal. I'm guessing lifting at the end is what caused the bending, right?....
Longer tines carry more brush. If you tip the bucket back they are equal strength to short tines. I have found that I like them long.
No questions about the quick attach huh? I've always wanted it and now that I have it I take them on/off several times a day. It rules!
Been using the stick rakes on the brush fork, for land cleanup. First I used them in drag mode, and drug up huge piles of sticks, blackberry brambles, and english ivy. Backed the brush hog over the piles and "reduced" them to mulch, which I scooped up and dumped over a bank. In the end I got tired of mulching, and needed to just push some stuff back into the weeds and get the heck out of there. So turned the stick rakes around. It's much more difficult to push than to drag. I kinda thought it would be a little more difficult, but it's very much more difficult.
Here's som pics. I built these 5 stick rakes one year ago, each one attaches to one fork tine with a pin.
Can see that one of my tines is bent. I'll bend it back it someday.
That makes sense about tipping bucket back, thanks for clarifying. I guess my thought is I'd have no problem with just brush with longer tines, but for firewood duty (a big use of them on our property) I'd need the logs back toward the bucket before lifting.
I get the quick attach. Very cool and useful.
