5' Rotary Cutter Options
   / 5' Rotary Cutter Options #41
RC, what is the difference between '306-1-TW' and '306-2-TW'?
Not seeing anything in the documentation. Thanks!
Single tail wheel (what I just bought) vs a dual rear tail wheels. View attachment 716133View attachment 716134
   / 5' Rotary Cutter Options #42
Here you can see the single and the smooth top heavy Guage steel.
   / 5' Rotary Cutter Options #43
I believe 1 Tailwheel vs 2 tailwheels
   / 5' Rotary Cutter Options #44
Very strange, but it has happened before. I didn't see a response to the question but after posting, It shows RC posted a few minutes before I did..
   / 5' Rotary Cutter Options #45
I understand that other people can have a different experience, but my Titan 72" cutter has bent every time it has had a chance. The specs look good but it looks twice as rough as my Brushbull even though is has been used less than 1/2 as much. I do contract mowing, so I subject it to more abuse,
I'm calling BS.... not because your BSing but because there are 2 Titan companies and many are unaware.
There is Titan Implements who are in Tennessee I believe. Products cut, bent, welded and assembled in USA.
Titan's headquarters and manufacturing facility is located in Decatur, Tennessee and was established in 2014 by father and son team, Mike and Baily Turner.
Then you have the China crap Titan. Also known as PalletForks.com.
   / 5' Rotary Cutter Options #48
Isn't that a little small?
I'd think it would look funny behind a mx.... Let alone your bigger tractor
yes, it is . lol. I don't bush hog very often . cows eat most of the grass.
I do have some small areas that works well with this small cutter, small 1-2'' saplings every now and again.
I had an older 6 footer that I sold some time back, and this is the only one I have at this time
It looks real funny behind the CX. The cutter only goes behind it when it's hot out and I want AC lol
I went to LMC (where these cutters are made) to look at a 7 footer but they said they were out at this time. Said they were selling as fast as they can make them. Probably should have kept the 6 footer, but I didn't want to rebuild it. It pretty much needed everything though
   / 5' Rotary Cutter Options #49
I've been looking at rotary cutters for a looong time. My choice is down to:
Brown 472 or Rhino TW36. I just haven't "jumped off the ledge" yet.
I will purchase with expected delivery in the spring of 2022.
I prefer the Rhino unit because - local dealers, like the design, stronger tail wheel.
Most ALL my cutting will be backing into brush and cutting field grass.
   / 5' Rotary Cutter Options #50
You should consider a BushHog BH316-2 as well, it's right in there with the Rhino specs and it may b a few hundred cheaper. I do recommend chains front and rear.
LOWRY 2020SB HD 7' DISC HARROW (A57192)
LOWRY 2020SB HD 7'...
UNUSED FUTURE FT-FR60 60" SIDE SHIFT FORKS (A57193)
UNUSED FUTURE...
2012 NISSAN 110 FORKLIFT (A55745)
2012 NISSAN 110...
40' CONTAINER (A57192)
500BBL SKIDDED FRAC TANK (A55745)
500BBL SKIDDED...
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
