5 minute backhoe thumb project
/ 5 minute backhoe thumb project
It's pretty close to the original bucket. Since I bought the smaller bucket, I may try moving it down.
I took a rough measurement and there are no other hole positions that will work. The next set of holes put it way down on the boom; too close to the bucket. I'm going to work with what I've got for a while.
/ 5 minute backhoe thumb project #13
Use the existing hole pattern and slide the assembly down the dipper to where you want it. You could fab up a triangular wedge using flat bar to make up the difference. Maybe even tack the wedge to your "thumb"
I was really going to do something like that to begin with, but before I headed out to buy the steel, I held up knife to the boom and was surprised at how well the holes lined up for the placement that I needed.
/ 5 minute backhoe thumb project #15
I would use 6" - 10" pieces of 3/8 flat bar between the bolt and the stick, both top and bottom. A few years ago there were several threads on bolt on thumbs that bent the stick.
/ 5 minute backhoe thumb project #16
What about going with 4 pieces of angle if bending the stick is of a concern?
/ 5 minute backhoe thumb project #17
I can see that happening.
2013 NEW HOLLAND WORKMASTER 35 TRACTOR (A62130)
2013 NEW HOLLAND...
2006 CATERPILLAR 320CL EXCAVATOR (A59823)
2006 CATERPILLAR...
KJ K2512 25'x12' Metal Shed (A60463)
KJ K2512 25'x12'...
2023 Bobcat T66 R-Series (A60462)
2023 Bobcat T66...
New Quick Attach Hay Spear (A61166)
New Quick Attach...
2014 BRENNER TANK CRUDE TRAILER (A60736)
2014 BRENNER TANK...
