5 minute backhoe thumb project
/ 5 minute backhoe thumb project #1
davel8257
odon, IN
Kioti DS4510HS
2 King Kutter Grader Box blade knives
2 Grade 8 1/2" x 6" bolts, nuts and washers
Attach box blade knives with bolts, tighten, check for clearance (my Kioti KB2485 cylinder just clears the 1/2" bolt).
There's no adjustment. But, it works if you can finagle the bucket into position for a good grab.
/ 5 minute backhoe thumb project #3
Awesome. Good move on the grade 8 bolts.
/ 5 minute backhoe thumb project #4
Best 5 minute project I've seen. Good thinking.
/ 5 minute backhoe thumb project #5
Whazzat wierd piece hose-clamped to the bucket cylinder?
/ 5 minute backhoe thumb project #6
Simple but effective....Good job!
Yep; SMV bracket. I need to remove the factory sign and either put it back there or on the ROPS.
/ 5 minute backhoe thumb project #10
Have you tried moving it closer to the bucket and moving the lower bolt one hole up to see how the teeth match up for like getting brush and limbs of a say a ditch? That is an awesome functional idea.
It's pretty close to the original bucket. Since I bought the smaller bucket, I may try moving it down.
I took a rough measurement and there are no other hole positions that will work. The next set of holes put it way down on the boom; too close to the bucket. I'm going to work with what I've got for a while.
/ 5 minute backhoe thumb project #13
Use the existing hole pattern and slide the assembly down the dipper to where you want it. You could fab up a triangular wedge using flat bar to make up the difference. Maybe even tack the wedge to your "thumb"
I was really going to do something like that to begin with, but before I headed out to buy the steel, I held up knife to the boom and was surprised at how well the holes lined up for the placement that I needed.
/ 5 minute backhoe thumb project #15
I would use 6" - 10" pieces of 3/8 flat bar between the bolt and the stick, both top and bottom. A few years ago there were several threads on bolt on thumbs that bent the stick.
/ 5 minute backhoe thumb project #16
What about going with 4 pieces of angle if bending the stick is of a concern?
/ 5 minute backhoe thumb project #17
I can see that happening.
2018 FORD F450 XL 4x4 CREWCAB 5K LB SERVICE CRANE (A62613)
2018 FORD F450 XL...
2024 CATERPILLAR 289D3 SKID STEER (A64279)
2024 CATERPILLAR...
UNUSED RANCH HAND BRUSH GUARD (A64280)
UNUSED RANCH HAND...
1000 Gal Tank (A64119)
2x4x8 Utility (A62613)
(2) 460R85R38 TIRES W/ (8) LUG WHEELS (A64280)
(2) 460R85R38...
