4x20 air filter alert
/ 4x20 air filter alert #1
Cidertom
Benton Co Oregon
JD 4520, 2305 Aktive snow-trac ST4
Manual says (paraphrase) don't touch the air filter until the fault alert happens. I went on and changed it (Primary) without the fault. To say the existing filter was loaded is an understatement. I checked the restriction alarm and it worked. I'm thinking I should have changed it last year by the amount of /caked/ dirt on the filter. Just a heads up.
CT
/ 4x20 air filter alert #2
I had the same experience. Secondary filter looked good along with the piping leading to the turbo. I took time to remove the air box and initial intake duct and clean them up well, firm up all clamps in the system and replaced both filters while I was at it. I've been forewarned by a couple diesel mechanics that maintaining the air filtration system is more important than even the lubrication/oil.
/ 4x20 air filter alert #3
SOP for me on my Kubota's is cleaning the primary intake filter every day when farming and changing the secondary yearly. Fuel is expensive.
/ 4x20 air filter alert #5
Interesting. Kubota uses a Donaldson type filter on the large frame tractors that's washable instead of dry.
All good points. I usually follow the manual, which in this case has a 'black box warning' :"Service filter elements only when red signal is in view in the instrument panel".
On my old 4300 it was a gauge I could see, and serviced when it started to creep up.
Most of this post was to alert others who did as I did and follow the manual. I'm going to change this to end of season at the latest. I do dump the dust unloader frequently.
2022 EZ-GO ELITE...
Metal American Flag Sasquatch (A65583)
Metal American...
2013 Chevrolet Express Cargo Van (A64556)
2013 Chevrolet...
Teakwood Rocking Horse (A65583)
Teakwood Rocking...
2018 Ford F-150 Crew Cab Pickup Truck (A64556)
2018 Ford F-150...
2022 EZ-GO ELITE...
