4wd. Question
/ 4wd. Question #1
scesnick
Garrett County Md. ( Western Md.)
Kubota MX5100
I finally ordered my parts from Hoye tractors to fix the 4wd on my 200BD. My question is this: Are the needle bearings ( #47) pressed on to the shaft ( #44) or are they just "tapped" onto the shaft with a rubber mallet? I didn't receive the parts yet, But this is the only thing I'm not sure about on the re-assembly. The schmatic is linked below, Thanks.....
4WD_INTERNAL: Yanmar Tractor Parts
/ 4wd. Question #2
Needle bearings should slide on .
/ 4wd. Question #3
Has it taken this long to get these parts or did you just recently order them? If it takes this long I might want to order now in order to have them in time for spring repairs!!
Greg
/ 4wd. Question #4
Greg
You get parts from Hoye in 3-4 days, depending on your location.
/ 4wd. Question #5
The same from us....3-4 days.
/ 4wd. Question
No, I was just putting it off, Trying to get my bigger snow removing toys ( Case 580 Backhoe ) up and running first. Of course this is all in between working 12 hr. shifts and yada, yada, Yada, the same "no time" story as everyone else I suppose.
FYI, these 2 needle bearings do NOT come in a set. I ordered the second one from LMTC today. $20.00 a piece everywhere I looked.
Unused 2026 Schulte SMR-800 Hydraulic Multi-Rake Skid Steer Attachment (A66734)
Unused 2026...
2009 INTERNATIONAL 4300 4X2 S/A DUMP TRUCK (A66091)
2009 INTERNATIONAL...
2005 Oskkosh MK48A1 8x8 Articulating Tactical Truck w/ MK14 20ft. Flatbed Container Hauling Trailer (A66736)
2005 Oskkosh...
CAT 315CL Manual Thumb (A68134)
CAT 315CL Manual...
JOHN DEERE 5075M TRACTOR (A63291)
JOHN DEERE 5075M...
DYNAPAC  CP271 PNEUMATIC ROLLER (A67714)
DYNAPAC CP271...
