4WD on the fly?
/ 4WD on the fly? #1
Will
Athens, Georgia
B2410HSD
I've found that if I'm driving my B2100DT straight with constant light load that I can shift between 2WD and 4WD without stopping or clutching. I just gently push the lever and in it goes without any fuss at all. This is very convenient if you are mowing up a damp hill and don't want to slip while driving up or tear up the lawn when you turn at the end.
I'm not sure I trust myself to tell the difference between a neat trick and a dumb idea. So what do you think, is this ok for the tractor?
/ 4WD on the fly? #2
As long as you keep the speed low and the pressure on the 4WD lever low, you should do ok. You are just engaging a gear that is turning pretty slowly. There is a slight danger that if you really mess up and have to clutch, you may also need brakes to keep from rolling back, but at low speeds that is unlikely.
/ 4WD on the fly? #3
I have the b2100hsd and have the same experience./w3tcompact/icons/cool.gif Most of the time I come to a full stop and change from 2 to 4. However, since it changes so smooth with out grinding, I still will change on the move altho only when moving slowly. Hope I never find out that what I am doing is really stupid./w3tcompact/icons/blush.gif
/ 4WD on the fly? #4
I don't know about Kubotas but with JD 790's and 2355's there is not the requirement to be stopped to shift into 4 wheel drive. Since the front axle parts and the driveshaft are always turning, the gears should just engage. This is just like the old 4 wheel drive vehicles with locking hubs, as long as the hubs are locked in, then you could shift in and out of 4 wheel drive when ever you wished.
2022 EZ-GO ELITE...
NEW Wolverine GB-11-72W Skid Steer Grapple Bucket (A62679)
NEW Wolverine...
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
3pt Hitch Receiver  (A62679)
3pt Hitch Receiver...
2025 Wolverine MCB-11-48W 48in Hydraulic 4-Way Clamshell Bucket Skid Steer Attachment (A64553)
2025 Wolverine...
2008 PETERBILT 365 (A65643)
2008 PETERBILT 365...
