4wd issue question
/ 4wd issue question #1
JayNorris
JohnDeere 410B 4wd
I have an 85 JD 410B 4wd... when all four tires off of the ground, all 4 wheels turn. Once down and weight on front end, front tires do not turn.. Any thoughts????
/ 4wd issue question #2
There was a recent thread about another guys tractor that was doing pretty much the same thing as yours. The problem on his was all the bolts on the ring gear had sheared off. With the tractor jacked up and the four tires off the ground, all four would rotate when driven by the engine but he could take his hand and stop the front tires from turning. There was just enough friction from the ring gear to the carrier it (used to be) bolted to so that it could still transfer a little bit of torque to the axle and turn the tires. Once the tires encountered the least bit of resistance, they would stop turning.
Sounds like you may have a similar situation with yours. Good luck and hope you get it figured out.
Thanks!
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
2020 JOHN DEERE 770G MOTORGRADER (A63276)
2020 JOHN DEERE...
2004 FRAC TANK 500BBL WHEELED (A63569)
2004 FRAC TANK...
2015 Mack Granite GU713  Tri-Axle Dump (A62613)
2015 Mack Granite...
ROANOKE S/A LOOSE LEAF TRAILER (A63291)
ROANOKE S/A LOOSE...
2003 Chevrolet Kodiak C4500 Flatbed 503372 (A62613)
2003 Chevrolet...
