4tnv88 Block Heater
/ 4tnv88 Block Heater #21
Snap-on Tools
I personally dont think the plug will be rusted so bad it wouldn't budge with light to moderate pressure but may well be wrong on that.
Square sockets up to 1 1/8" not cheap but its an idea. This would eliminate the pipe wrench and give a person pretty much unlimited torque capability out away from the tractor with extensions and long bars cheaters etc. This may not work for average guy in his garage but I loosen things I presume are going or prove to be rusted bad with an air hammer and heat fwtw.
/ 4tnv88 Block Heater #22
I think I will think about this some more. Clearly the starter has to be removed to gain access to this plug. It looks to be about a 1 inch square. I wonder if a socket would grab on to this tight enough.
In any event, when/if I tackle this....I will add some heat and see if I can get it to budge....if not...I might just punt on this project. But I really think it will go ;) I am just hesitant as I do not want to break anything that involves a yanmar block!
I don't think that HF adapter set has what you need, but I agree a square socket is the way to go. Your local NAPA store should be able to get the square socket with whatever drive size you want.
/ 4tnv88 Block Heater #27
I took the easy way out. 3 years ago I bought a magnetic block heater, about half the size of a brick and 450 watts, stuck it on the right side of the block, and it's been there ever since. Plug it in about an hour before I need to start the tractor and she fires right up. Without it, I would have quite a struggle at anything below 35 degrees or so. I only turn a wrench when I HAVE to. This was a simple, cheap, and very effective solution.
/ 4tnv88 Block Heater #28
I didn't have that kind of luck with the 450w magnet heater I bought unfortunately. It was the easiest solution alright but it did nothing to help start mine. I went to a soft plug heater and it works in about an hour the engine will start on a 20 degree day pretty nicely.
/ 4tnv88 Block Heater #29
I was thinking the same thing.....and I may have something like that already otherwise a trip to HF
You can always try a 12pt socket first Scotty if it strips it wont hurt the plug to where a square socket or pipe wrench wouldn't work. Some valve grinding compound smeared around the inside of the socket may give it enough grip not to slip dunno?
/ 4tnv88 Block Heater #30
Soak it for a while with some PB Blaster. The stuff works miracles.
UNUSED WOLVERINE HYD ADJUSTABLE BALE SQUEEZE (A64281)
UNUSED WOLVERINE...
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A65053)
2016 CATERPILLAR...
John Deere Mini Decorative Truck (A61574)
John Deere Mini...
2019 KUBOTA KX057-4 EXCAVATOR (A62129)
2019 KUBOTA...
2014 GMC Yukon SUV (A61574)
2014 GMC Yukon SUV...
iDrive TDS-2010H...
