4th day with no power
   / 4th day with no power #11
A pto gen set is better then sitting in the dark...
I agree with that but not a ton better. A pto powered genset still has to be hooked up to the tractor and the safest way is powered through a vacuum breaker transfer switch, hard wired into the house mains, something I would bet most owners of them never consider. Of course you have to keep fueling the tractor and keeping an eye on fluid levels too. My unit draws directly from my diesel bulk tank and has auto shutdown in case of low fluid levels, something I've never had to deal with. The JD turbo diesel engine uses no oil and the liquid cooling system is tight with no leaks. Sure it has to be maintained but so does a tractor.
   / 4th day with no power #12
I prefer my pto generator and lots of choice of tractors to run it with. Over 25 years of use and still ready to produce power.
Do you do the 'extension cord' thing or do you have a dedicated transfer switch? I have choices in tractors as well (as you know), but I prefer the standby especially for my wife if I'm not home which was the case prior to retirement.
   / 4th day with no power #13
I know what you're going through. We had a 7 day outage after hurricane Sandy in 2012. We only had a 750 watt Honda genny which we used for charging cell phones, TV, lights & computer. No water A/C, cooking or refrigeration. We had to siphon gas from our 3 vehicles since no nearby stations were pumping. Showered at a relatives place 45 minutes away. It got old very quickly.
After that incident, I bought a 12KW PTO generator powered by my Kubota. I fuel the tractor from my 1000 gal heating oil tank which would last a month if necessary. Only used it twice for short outages since.
Here's another trick I used during that 7 day outage to supplement our tiny Honda genny:
The local Home depot was open and running on generator power but there wasn't a battery, propane lantern or flashlight to be had. I went to the outdoor lighting section and bought a dozen solar powered walkway lights. I set them outside to charge during the day and brought them in for room lighting at night.
   / 4th day with no power #14
Just curious, do the solar walkway lights have an off/on switch?
   / 4th day with no power #15
Should have. I know all that my wife buys (she's into solar lights) have a slide switch on them.
   / 4th day with no power #16
In the 20 years I've been here my power has been out for more than 20 hours exactly once, and that was about 6 months ago. I don't need instant power if it does go out, nor do I need it to run 24/7. A PTO generator makes more sense for my needs, and I plan to pick one up before winter. To me it's just swapping out another implement, something I do on a regular basis.
I do also have a manual transfer switch; again, that's all that I really need.
   / 4th day with no power #17
We too had the most lengthy outage we have ever encountered. I bought a 3500w inverter.
It will power the fridge, freezers, fans, chargers, etc. It was liveable. The air fryer will run, and I have a gravity fed charcoal smoker to boot. It was like camping, but much more comfortable.
We have an 86 gallon pressure tank for the well, so we had toilets working at all times.
Eventually I'd like to have a whole home unit, probably at the next property we build. For now, keeping food fresh and cooking it will suffice. It's actually sort of nice not to have every other distraction.
   / 4th day with no power #19
Cord from the generator transfer breaker to the generator.
It's not hard to hook up, the hardest part is backing up the generator trailer.
My wife can do the transfer if needed. When a winter storm is forecast I will often back it up and connect it, then plug in the tractor and let her set ready to go.
It does not have an auto start, which would be nice but when I got the generator I paid less then $2000 for the 25KW unit.
I can get dressed and go outside for the difference in that and an auto standby unit. I have considered a standby unit but $$$$$
makes me decide to keep the pto unit.
Plus, there have been a couple of times that I loaned out the generator when I didn't need it. And it is a portable 25KW unit.
   / 4th day with no power #20
No, you just twist the cap off and remove the battery.
Easy enough, I like your solar "flashlight" idea. Or for that matter anything where someone thinks outside the box to accomplish something!
EXCAVATOR RIPPER (A58214)
EXCAVATOR RIPPER...
WATER TRAILER (A58214)
48" Pallet Forks (A59814)
48" Pallet Forks...
2005 GMC Canyon (A57148)
2005 GMC Canyon...
2020 INTERNATIONAL MV607 (A58214)
2020 INTERNATIONAL...
2015 Acura ILX Sedan (A59231)
2015 Acura ILX...
