4ft Ditch Bank Mower
/ 4ft Ditch Bank Mower #1
5 Shot
Mahindra
I have a Mahindra 4540 and looking into getting a ditch bank rotary cutter mower for it. I see lots of flail mowers but not many rotary cutter type. I have chance at a Hardee 5ft but I think its too much for my tractor. Hardee makes a 4ft one at $9500 but I haven't seen any other models. Anyone know of any other models? Thanks
/ 4ft Ditch Bank Mower #2
First off welcome to TBN.
Next you might get a better response if you post this over in the Attachments forum instead of parts/repairs.
And lastly - as a fellow who would love a Ditch / Bank mower of some type, I have done a lot of shopping and you can buy a LOT of flail for $9500 - is there a reason you're set on a rotary style cutter?
If you're doing something light duty or don't mow that often - a few users here have tried the Chinese Flails like Betstco, Farmers Helper, and Titan and reported good luck with them.
A 5' Light Duty can be had for around $2,200 - $2,900
65″ VL-AGL Gold Ditch Bank Flail Mower, VL-AGLC165 | Betstco
Titan 65" 3-Point Offset Flail Ditch Bank Mower
One point to note - even though they all come from China with the same Model Number (AGL-165 in this case) - they are NOT all made the same as they come from different factories / companies using the same basic design.
TBN User Jack Yuan is a great guy to contact about these mowers and which factories are taking shortcuts and which aren't. He will not give a Mfg opinion in open forum so you'll have to message him but he has several post over in the attachments forum if you start searching for Flail & titan you should find them.
Also TBN user Leonz is probably the closest thing to a Flail Guru that ever existed. He can likewise be found over in the attachments section on pretty much any thread dealing with Flail mowers.
Best of luck with whatever you decide to do. Be sure to post back here so folks like me can learn & benefit too.
/ 4ft Ditch Bank Mower #3
You ever think about a drum? SFI in Caldwell, TX. is a drum dealer and has a www and some Utube videos on the use of one. i think they come in 4'; mine is a 2 drum 6'....just larger diameter. It sits off to the side and can be run in or out of water while your tractor is up on dry ground. Very, very, rugged and maintenance free. He posts the cost and recommended hp.......wayyyyyyy lower than the price you quoted and gonna bet would do you a whole lot better.
The tractor hp recommendation listed has more to do with the tractor having enough weight to handle an implement mounted off to the side when being transported, than what it takes to spin the blades and push the mower through the resistance of tall grass. When mowing it sits on the ground and is an aid in preventing roll overs on steep banks since it's locked to your 3 pt.
24" Mini Excavator Bucket (A66285)
24" Mini Excavator...
1999 Volvo Sleeper (A62613)
1999 Volvo Sleeper...
2024 JCB 35Z-1 EXCAVATOR (A65053)
2024 JCB 35Z-1...
2022 CATERPILLAR 299D3 XE SKID STEER (A65053)
2022 CATERPILLAR...
New/Unused Landhonor 26ft x 13ft Metal Carport (A65583)
New/Unused...
John Deere 5055E (A64126)
John Deere 5055E...
