4720h Draft Control
/ 4720h Draft Control
Draft control was standard in my 2010 model but it's possible they've made it an option on the newer models. You might check with your dealer. It's possible that it could be added but I'm not sure.
/ 4720h Draft Control #24
MY 2012 4020R doesn't have it either. I was told it was left off because people were not using it. I quess the hobby farmers didn't know what it was for. I have plowed with it, but I wanted to see if it might help with a box blade. Auto lift and drop according to pull is what I wanted to try.
/ 4720h Draft Control #25
US models don't get draft control, although some older models might have. My guess is somewhere from 2012 and on. The EU and AU models get draft control.
The Operators manual is quite vague about draft control and the service manual is not great either but helps a bit when using the info from both models.
Here is a picture from the service manual to explain:
On mine, I just played with the shims and moved the part C all the way back, put the shims on front and tighten the bolts. When I'm not using draft, I just lock it with the swinging spacer on top of the top link bracket. When I need draft, I just swing the spacer and go on.
2013 Ford Taurus AWD Sedan (A64557)
2013 Ford Taurus...
213098 (A64276)
213098 (A64276)
2025 Rippa IREAS Ripper Mini Excavator Attachment (A64553)
2025 Rippa IREAS...
Welcome to the Ranch Metal Decorative Sign (A64557)
Welcome to the...
Club Car Carryall 6 Medical Utility Cart (A64553)
Club Car Carryall...
2006 International 4200 2,000 Gallon Water Truck (A64553)
2006 International...
