4720 with MX7
/ 4720 with MX7 #1
Raven7
Sleepy Eye, MN
John Deere
After reading about others using the MX7 mower behind a 4720 tractor with good success I purchased a like-new MX7. Today I went to hook it up for the first time and found that the MX7 is a category 2 and does not fit on the category 1 hitch on the 4720. I know others are using this combo. What's the trick to making this work?
Thanks for your input.
/ 4720 with MX7 #2
:welcome: to TBN
I believe it is just a matter of changing it back to the original cat I.
Do you have an iMatch quick hitch?
Looking at jdparts.com they show a conversion kit to change from Cat I to Cat II, so I suspect yours has that kit that needs to come off.
Can you post a pic of what you have now?
/ 4720 with MX7 #3
My mx7 is only cat2 from what I was told. It's 1300 lbs and sticks way out there. It's the reason I had to go with the cat 2 quick hitch.
Good luck
Brett
/ 4720 with MX7
The MX7 I have is one year old and came from the factory with a cat 2 setup. Also, when I checked the JD website it indicates the MX7 is cat 2. I will take some pics in the a.m.
/ 4720 with MX7 #5
Tractor Supply (TSC) has hitch bushings for this.
/ 4720 with MX7 #6
get the Imatch hitch and you are done.....PLUS you will enjoy it with your other 3 pt implements. Consider it a cost of buying the MX7
/ 4720 with MX7 #7
You have to use a cat II hitch. The JD one is $580. If your three pt isn't cat 2, it won't fit.
Brett
ENCLOSED OPERATOR CAB (A68842)
ENCLOSED OPERATOR...
2007 CAT 140H MOTOR GRADER (A67714)
2007 CAT 140H...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2018 GENERAC...
PALLET OF DISCHARGE HOSES MISC SIZES (A67714)
PALLET OF...
PALLET OF 1 5/8 HYDRAULIC HOSES (A67714)
PALLET OF 1 5/8...
2010 Honda Civic Sedan (A66738)
2010 Honda Civic...
