4720 with MX7
/ 4720 with MX7 #1
Raven7
Sleepy Eye, MN
John Deere
After reading about others using the MX7 mower behind a 4720 tractor with good success I purchased a like-new MX7. Today I went to hook it up for the first time and found that the MX7 is a category 2 and does not fit on the category 1 hitch on the 4720. I know others are using this combo. What's the trick to making this work?
Thanks for your input.
/ 4720 with MX7 #2
:welcome: to TBN
I believe it is just a matter of changing it back to the original cat I.
Do you have an iMatch quick hitch?
Looking at jdparts.com they show a conversion kit to change from Cat I to Cat II, so I suspect yours has that kit that needs to come off.
Can you post a pic of what you have now?
/ 4720 with MX7 #3
My mx7 is only cat2 from what I was told. It's 1300 lbs and sticks way out there. It's the reason I had to go with the cat 2 quick hitch.
Good luck
Brett
/ 4720 with MX7
The MX7 I have is one year old and came from the factory with a cat 2 setup. Also, when I checked the JD website it indicates the MX7 is cat 2. I will take some pics in the a.m.
/ 4720 with MX7 #5
Tractor Supply (TSC) has hitch bushings for this.
/ 4720 with MX7 #6
get the Imatch hitch and you are done.....PLUS you will enjoy it with your other 3 pt implements. Consider it a cost of buying the MX7
/ 4720 with MX7 #7
You have to use a cat II hitch. The JD one is $580. If your three pt isn't cat 2, it won't fit.
Brett
ABI 80-ASRT-074 Command Seeder Tractor Attachment (A61572)
ABI 80-ASRT-074...
(2) UNUSED 23X8.50-16 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED...
2015 FORD F-350 SUPER DUTY (A63569)
2015 FORD F-350...
Dexter trailer axles (A61567)
Dexter trailer...
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
UNUSED ATS POWER ATS-PC90 HEAVY DUTY PLATE COMPACT (A64281)
UNUSED ATS POWER...
