4720 with CAB , E-PTO lever location ?? Help
/ 4720 with CAB , E-PTO lever location ?? Help #1
Brown Dog
North GA
John Deere 5115M 5101E H260 5115M 540M all MFD
I know the open station epto lever is on right side behind the seat, right beside the mid pto engagement lever if equipped.
I'm looking at a cab unit that has the epto on tach at 1750rpms.
But I can't find a lever.
There's NO levers behind the seat.
The owners manual shows a "PTO" lever on far right fender, beside the loader joystick ....
This tractor doesn't have a lever in that outer slot ...
Any help appreciated.
/ 4720 with CAB , E-PTO lever location ?? Help #2
Tach will be marked for ePTO even if the tractor does not have that option.
/ 4720 with CAB , E-PTO lever location ?? Help #3
Yep what Zebra said, all the 4x20's tach have the marking on the face of the dial whether it has the option installed or not.
The epto lever is outside the back window, on right side.
Long rod with yellow knob.
I just pulled the trigger on a Low Hour 4720 open station,
SL Loader, E-PTO & Turf tires :D
To join my 4700, 5425 & 6410 units.
I Love the 4k series for mowing with my 110" Befco RFM.
/ 4720 with CAB , E-PTO lever location ?? Help #6
Ehydro B range on my 4120 go pedal on the floor I mow at 6.5 mph and turns on a dime. I love mowing on it. Hit the cruise in the longer runs.
/ 4720 with CAB , E-PTO lever location ?? Help #8
R4's set to narrow
I got tubes put in all 4 turf tires today & filled with fluid on my open station.
I swapped my frt tires to the Wide Setting :D
I set eng at 2,000 rpm's IN epto setting & the Befco 110" RFM mows so much smoother now.
I sure am liking the HydrO tranny for mowing.
2022 EZ-GO ELITE...
New 1.5x27 Ratchet Strap (A65583)
New 1.5x27 Ratchet...
2017 Hino 155 16ft. Box Truck (A64556)
2017 Hino 155...
2015 Honda Accord Sedan (A64557)
2015 Honda Accord...
VERMEER FT 100 FORESTRY MULCHER (A65053)
VERMEER FT 100...
Metal Donkey (A65583)
