4720 Rops Heighth?
/ 4720 Rops Heighth? #1
TCowner
Platinum Member
SE Minnesota
John Deere 4720 Cab
I am looking at a possible trade of my TC40DA on a JD 4720. My TC will clear my garage door opening if I drop the rear tire pressure just a bit. It's nice to work in the garage rather than in the pole shed.
If I purchase the 4720 it will be an open station tractor with a Curtis Cab. The cab on the TC requires the ROPS to stay upright as the rear window and frame clamps to it. I can't raise and lower it if I need access to the garage. I would suspect the Curtis cab for the JD would be somewhat similar.
I need to find out the exact heighth of the 4000 series tractors with the industrial tires. Anyone have a tape measure handy? JD's website doesn't list the heighth under the specs page.
/ 4720 Rops Heighth? #2
The manual lists it as 2.5m or 97.2", but if you need to squeak under the garage door I don't know how much variation there is based on tire type/inflation or simple build variation. It's also possible that the cab rests on top of the ROPS, adding a little more height to the setup.
