Buying Advice 4720 or 5085m
/ 4720 or 5085m #61
PowerReverser tranny does not require the use of a clutch after you have selected the Range and Gear. Orange handle lever to the right of the steering wheel - flip it up and down - forward and reverse; and neutral. You need to use the clutch to change the Gears (1-4); and you have to stop the tractor and use the clutch to shift Range's as well.
With a SyncShuttle you have to use the clutch for everything. Forward - Reverse; Range (stop tractor) and Gear changes. Transmission is synchronized so you can change gears while moving.
PowerReverser is similar to driving a forklift or a construction loader.
SyncShuttle is like driving your Dad's SS Camaro or Chevelle with a 4-speed!
AKfish
Actually a 3 speed with a reverse! :laughing:
But usually on the road I skip D2. Just go to D1 to D3. One thing I like about the transmission is it lines it self up to Gear 2 and 3 when you pull it out of Gear 1.
/ 4720 or 5085m
Do you guys go through the gears like listed? A1, 2, 3, 4, then put range into B and gear into 1 then 2, ect. Or do you just pick a range and gear and use that directly? (Both scenarios when traveling and working.)
/ 4720 or 5085m #63
When I'm on the road, I usually start from D1 then work my way up. But on a syncshuttle I skip Gear 2 because its not much faster than D1. But when working in a lower range I just start say in B2 or B3.
PREVIEW DATES AND TIMES (A65583)
PREVIEW DATES AND...
2008 Chevrolet Silverado 2500 Crew Cab (A62613)
2008 Chevrolet...
(2) DOUBLE AXLE FENDERS (A64280)
(2) DOUBLE AXLE...
GEMTOP WORKMASTER TRUCK BED COVER (A64281)
GEMTOP WORKMASTER...
JOHN DEERE 4560 TRACTOR (A64280)
JOHN DEERE 4560...
2000 Artic Cat ZR600 Limited Edition Snow Mobile (A62613)
2000 Artic Cat...
