Buying Advice 4720 or 5085m
/ 4720 or 5085m #61
PowerReverser tranny does not require the use of a clutch after you have selected the Range and Gear. Orange handle lever to the right of the steering wheel - flip it up and down - forward and reverse; and neutral. You need to use the clutch to change the Gears (1-4); and you have to stop the tractor and use the clutch to shift Range's as well.
With a SyncShuttle you have to use the clutch for everything. Forward - Reverse; Range (stop tractor) and Gear changes. Transmission is synchronized so you can change gears while moving.
PowerReverser is similar to driving a forklift or a construction loader.
SyncShuttle is like driving your Dad's SS Camaro or Chevelle with a 4-speed!
AKfish
Actually a 3 speed with a reverse! :laughing:
But usually on the road I skip D2. Just go to D1 to D3. One thing I like about the transmission is it lines it self up to Gear 2 and 3 when you pull it out of Gear 1.
/ 4720 or 5085m
Do you guys go through the gears like listed? A1, 2, 3, 4, then put range into B and gear into 1 then 2, ect. Or do you just pick a range and gear and use that directly? (Both scenarios when traveling and working.)
/ 4720 or 5085m #63
When I'm on the road, I usually start from D1 then work my way up. But on a syncshuttle I skip Gear 2 because its not much faster than D1. But when working in a lower range I just start say in B2 or B3.
2015 INTERNATIONAL PROSTAR (INOPERABLE) (A63569)
2015 INTERNATIONAL...
Coats 5060AX Rim Clamp (A63118)
Coats 5060AX Rim...
2008 Toyota Camry Sedan (A61574)
2008 Toyota Camry...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
2021 WACKER NEUSON LIGHT TOWER (A63569)
2021 WACKER NEUSON...
2014 Magnum 7696BLA Light Tower (A59213)
2014 Magnum...
