thanks. My neighbor used an adjustable wrench to loosen it. When I tried it the wrench kept on slipping off.
I tried to use an adjustable wrench on it before my neighbor did. he is more persistent then me.The "slipping off" part of that I do not understand.. especially if it was already loose.
As posted above, the plug is JD part # RE46687, which is M22 x 1.5 and there is an O-ring that goes on for a seal. The O-ring is part # 51M7045
Sounds like it was tightened too tight and now buggered up..... When replacing, snug is good, any tighter not so good. Good that you are getting the oil and filter changed. Hope it ends well...
It appears to be a 22MM. How I found this went to John Deere parts
John Deere Parts Catalog
The drain plug part number is RE46687 and did a google search and found this
https://ezoildrainvalve.com/uploads/3/5/2/6/35266975/ez_comprehensive_chart.pdf
Here is the owners manual if you need it
OMLVU19619_E9
That should work, 1.063" is the same as 27mmI use a 1-1/16" on my 4720. dsb
JD5210 I tried 22mm but it was too small. The neighbor who loosened it with the adjustable wrench measured it to be 27mm which is about the same as what dsb5610 said, 1 1/16?
I will try to get a replacement but at autozone since I get bad vibes at advance. Thanks TractorGuy.
