4700 question
/ 4700 question #1
deere755
Platinum Member
central Illinois near Lake Shelbyville
Case 2090 Massey Ferguson 4233 John Deere 4700
I did a full service on my 4700 this evening. Oil, oil filter, both air filters, transmition filter, lube and fuel filter. After I was finished I started it up and let it run for a bit. I noticed a lot of blue grey looking smoke. The tractor has sat all winter with the exception of starting it a few times and letting it idle for a while. I took it out and put it on a 10 foot wheel disk this evening and it really smoked for a bit and then I noticed a lot of sparks coming from the exhaust and then the smoke cleared up and ran like always. The tractor never ran bad seemed to have plenty of power just some blue grey smoke. I am thinking maybe sitting and the idling made it carbon up a bit and pulling it and getting it good and warm blew all the carbon out. I ran it about an hour and the engine oil was as clear as it was when I dumped it in. What is your take on it? Anything I need to worry about? One last thing the oil had about 100 hours on it when I changed it and I always change at 100 hours or every spring which ever comes first. I use John Deere plus 50 15w40. Tractor has 2100 hours.
/ 4700 question #2
I'd guess that you had an accumulation of incompletely burned fuel in the exhaust system. Likely built up during this past winter when the tractor was ideling for short periods of time without really warming up.
Did you notice the end of the exhaust pipe? Look like it was wet at the end of the pipe? Wet sheen extending 2-3 inches up the side of the pipe?
The grey, white (blue) smoke at startup should disappear with some working hours. Bears watching, though... could be a sticky injector.
AKfish
/ 4700 question
Thanks for the reply. I ran it all day today with no blue grey smoke. I am confident it is ok. (I hope anyway) I didn't notice any wetness around the pipe. Had plenty of power.
CATERPILLAR D9T CRAWLER DOZER (A64279)
CATERPILLAR D9T...
Meteer 6R Corn Head Reel (A66408)
Meteer 6R Corn...
Landhonor TP2-13-08D Skid Steer Mount Tree Puller  (A62679)
Landhonor...
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
2000 Chevrolet Astro Van (A64194)
2000 Chevrolet...
Longhorns (A65583)
Longhorns (A65583)
