4690 BH pump kit
/ 4690 BH pump kit #11
The setups I mentioned do not require a reservoir on the backhoe (except the PTO pump, of course), even though the backhoe (Bradco 609) on my tractor (L4310HST) is the largest you're likely going to find on a compact utility tractor. I'm not sure what you're talking about when you use the term "excess fluid".
Contamination is an issue, of course, but in my case I have a number of 3-point implements that use the hydraulics anyway, so I'm used to it. It's just a matter of keeping the fittings clean. That's what filters are for. I'm not trying to be smart, but to me it's kinda like not using the tractor because you'll wear the engine out. That's what I bought it for. I've got all that hydraulic flow and pressure for a reason: to do work - and you can bet I'm going to get my money's worth out of it. The Bradco backhoe has its own filters, as well, so it's protected and helps protect the tractor, too, for that matter.
/ 4690 BH pump kit #12
Mark,
The excess fluid I was concerned about is that volume of fluid that must be "available" in the worst case combination of cylinder positions, or "stored" in the opposite situation. The 2710 holds a total of ~ 3 gallons of fluid (of which only a part is available), the 4690 hoe holds about the same volume in its system/resovoir.
The 2710 has about 9.5 gal/min flow capability but I'm not sure how much is really available in the power beyond port accessable at the rear of the differential case. I don't know the output of the PTO pump.
I am OK with the fittings issue, but as a choice of systems (not including the frame/3-point issue), the PTO pump seems a good approach for me (I have a mid mount mower). If I did not have a mid mount mower and the need for one, I would have a frame mount hoe.
Pete
B2710/LA401/4690
/ 4690 BH pump kit #13
Look at it this way: The cylinders can't move faster than the fluid pushed in (or pulled in and let out if gravity is the force actuating it). So there's no "excess". The backhoe is always "full", meaning there's always fluid in all the hoses, both ends of each cylinder, etc. When you connect, there's a little air introduced, but it's soon flushed to tank and that's that.
I'd never thought about the fact that mid-mount mowers preclude the posibility of a frame mount backhoe. When you get into the larger and heavier duty backhoes, a frame mount is necessary to prevent damage to the tractor.
/ 4690 BH pump kit #14
MCHALKLEY-- that was your shortest post yet. Way to go guy I knew you had it in you.
/ 4690 BH pump kit #15
I've had a very hectic schedule for the past few days - necessity is the mother of invention. /w3tcompact/icons/wink.gif
2025 MMS MS36C (A60463)
2025 MMS MS36C...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A61307)
Bulk Lot of NEW...
2017 Ford F-250 Pickup Truck, VIN # 1FT7W2B63HED67208 (A61165)
2017 Ford F-250...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
IREV High End Electric Scooter (A60463)
IREV High End...
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
