4672 BH question
/ 4672 BH question #1
dty
New Jersey
Kubota 7610
When the dealer first dropped off my 7610 with a 4672 BH, the BH limiter rested snuggly on the lower 3ph links.
Now that I have taken the BH off and on a few times, the limiter sits about 1/8" - 1/4" above the lower links...they don't touch at all.
Is this normal or should they be touching? /forums/images/graemlins/confused.gif
Thanks.
/ 4672 BH question #2
I have the 4690, but you mean that the limiter bar is UNDER the lower arms, right?
It is a back up safety device from what I understand and does nothing if the top link bracket or pin holding the backhoe to it doesn't fail.
Mine has some clearance under the lower arms...
I consider it normal that there is some space beteen the limiter bar and the lower arms. Don't know if this is the right answer or not, but I comfortable with it in my case.
You certainly want the limiter bar to be below the lower arms though. VERY important that it is...
/ 4672 BH question
thanks Henro. The limiter is definitely under the lower links, so I guess I'm doing it right.
I've got BH installation down to 20 min so far /forums/images/graemlins/grin.gif I'd like to it get down to 5.
2000 CATERPILLAR 322BL EXCAVATOR (A65053)
2000 CATERPILLAR...
2023 WALLACE-THE ROOSTER ROOT PICKER PINTLE HITCH (A65054)
2023 WALLACE-THE...
2022 Kubota Z422-54 Zero Turn Mower (A63689)
2022 Kubota...
2012 COMPTANK  ACID TRANSPORT TRAILER (A67714)
2012 COMPTANK...
TIRE RACK WITH TIRES (A67714)
TIRE RACK WITH...
2019 Dodge Durango SUV (A66738)
2019 Dodge Durango...
