4672 BH question
/ 4672 BH question #1
dty
New Jersey
Kubota 7610
When the dealer first dropped off my 7610 with a 4672 BH, the BH limiter rested snuggly on the lower 3ph links.
Now that I have taken the BH off and on a few times, the limiter sits about 1/8" - 1/4" above the lower links...they don't touch at all.
Is this normal or should they be touching? /forums/images/graemlins/confused.gif
Thanks.
/ 4672 BH question #2
I have the 4690, but you mean that the limiter bar is UNDER the lower arms, right?
It is a back up safety device from what I understand and does nothing if the top link bracket or pin holding the backhoe to it doesn't fail.
Mine has some clearance under the lower arms...
I consider it normal that there is some space beteen the limiter bar and the lower arms. Don't know if this is the right answer or not, but I comfortable with it in my case.
You certainly want the limiter bar to be below the lower arms though. VERY important that it is...
/ 4672 BH question
thanks Henro. The limiter is definitely under the lower links, so I guess I'm doing it right.
I've got BH installation down to 20 min so far /forums/images/graemlins/grin.gif I'd like to it get down to 5.
2017 Ford Explorer AWD SUV (A66738)
2017 Ford Explorer...
207923 (A63290)
207923 (A63290)
2011 INTERNATIONAL MA025 SERVICE TRUCK (A66091)
2011 INTERNATIONAL...
THREE METAL FRAMES (A68842)
THREE METAL FRAMES...
1987 Fruehauf MC 307 Insulated 7,500 Gallon T/A Chemical Tanker Trailer (A68183)
1987 Fruehauf MC...
2006 Hummer H3 4x4 SUV (A64557)
2006 Hummer H3 4x4...
