467 John Deere Baler problem
/ 467 John Deere Baler problem #1
BALER
FORNEY, TEXAS
JOHN DEERE 6410
Help my door latch starts to open when I start rolling hay. Any help would be great
/ 467 John Deere Baler problem #2
On my 335, if hay is pretty dry, there will be a build up of finer chaff in the back loop, and drops under the bottom roller bar. When I close the door, there is enough pressure on the hydraulics, to kick it back to the neutral position. But yet, the door is not completely closed, or belts tight, once the PTO is re-engaged.
I just got in the habit of starting the baler at low rpm's, then nudge the hydraulic control to close again. Mine has the manual bale size indicator. I can tell when it starts building up, because it will not go completely back to where it should be. With PTO engaged, and nudge the hydraulics, the indicator will jump to where it should, and belts are tight, and door closed.
In extremely dry hay, I'll clean it every 15-20 bales.
2025 SAWYER 85BP20 20FT T/A ENCLOSED BUMPER PULL TRAILER (A59912)
2025 SAWYER 85BP20...
2017 Ford F-150 Pickup Truck (A61573)
2017 Ford F-150...
2025 Hydraulic Stump Grinder Mini Skid Steer Attachment (A61572)
2025 Hydraulic...
2025 Kubota L2502HST (A64119)
2025 Kubota...
2022 Ford Explorer AWD SUV (A61574)
2022 Ford Explorer...
2016 Deere 180G (A60462)
2016 Deere 180G...
