4630hst value
/ 4630hst value #1
930ck
southcentral kansas
allis d 17/ case 930, 1370/ kubota L5740
Found a 4630 hst fwd fel with 600 hr salesman not sure of yr, between 03 and 06, no rear remotes asking 21000 seems a little high so thought i would ask. Just found this site and have been looking for a tractor with around 50 hp with hydro fwd fel but with at least one remote. Main u:cool:se will be 6 ft mower and piling brush. Any recomemdations are helpful . Thanks.
/ 4630hst value #2
That is a bit high for an open station, is it a cab tractor?
He should be able to give you a much closer date.
You can determine when the engine was built Year & Month using this: Kubota Engine America - Compact Diesel Engines
If they stick to that price they should also give you a Couple Pair of rear remotes AND plumb in a third function on the loader (for aux hydraulics, grapple or 4N1 bucket use).
KennyV
/ 4630hst value
Thought it was on the high side (no cab) it is at a jd dealership but kubota dealer said adding one remote would be close to $1000 and he could get me in a comparable new tractor for $26000 including one rear remote. Was wanting to get a used tractor but it appears that what most have told me may be cheaper in long run to buy new. Wanting to stay with local brands(kubota,jd,caseih,mahindra)
Danuser 3pt Auger (A64119)
Danuser 3pt Auger...
John Deere TX Gator (A60462)
John Deere TX...
2019 CATERPILLAR 326FL EXCAVATOR (A62129)
2019 CATERPILLAR...
ROANOKE LONG ARM DITCH BANK MOWER (A63291)
ROANOKE LONG ARM...
2011 John Deere 5085 70HP Utility Tractor (A60352)
2011 John Deere...
43024 (A59228)
43024 (A59228)
