4600's pto not working?
/ 4600's pto not working? #1
IslandManMitch
Bronze Member
Pineywoods of Florida
John Deere 4600
Hooked up the bush hog to my 4600 yesterday and no pto? The dash light comes on and if you raise off the seat the engine dies like it is running. I have 12 volts to the solenoid. Ohm meter says I am getting continuity through the solenoid. A new solenoid is about a hundred bucks and I want to make sure that is the problem before I buy it and find out the pto valve is stuck or something worse. Any way to trouble shoot other ideas?
I noticed this was never answered. Maybe someone else has this problem and is searching. This is what I found. The rod that works the PTO valve was stuck. To fix. Remove your PTO solenoid. Pull the rod out of the PTO valve. Clean rod, replace and should work fine.
/ 4600's pto not working? #3
Thanks for posting the fix. I am sure it will help the next guy down the road!!!
/ 4600's pto not working? #4
Yep, followups are greatly appreciated, we all wan't to know what the cure was for what ails your tractors. That is a good way to learn.
Steve
2016 Ford Fusion S Sedan (A59231)
2016 Ford Fusion S...
Kubota SVL 75-2 (A60462)
Kubota SVL 75-2...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
2025 Kivel 48in. Forks and Frame Skid Steer Attachment (A59228)
2025 Kivel 48in...
2025 30in. Pallet Forks and Frame Skid Steer Attachment (A59228)
2025 30in. Pallet...
2019 FREIGHTLINER WATER TRUCK (A58214)
2019 FREIGHTLINER...
