4600 Reverse in 3rd gear position.
   / 4600 Reverse in 3rd gear position. #1
petebert
Outside of Ann Arbor
If we think of the shifter as
A B C
D E
I'm getting reverse in D and E, also 1 low isn't any slower than 2 low.
   / 4600 Reverse in 3rd gear position. #2
What transmission do you have.. Post the model I'd #.
Twin stick,right?
Yes twin stick, which serial do you need? The transmission case is stamped D5-NN-7006 P
I think this is what you need more, looks like the model is CU212K, transmission is 8023C
Did some googling, it appears that this "4600" would be a 335 that somebody put a lot of effort of dressing up as a 4600. Also found the gear chart below, explains why what I thought was 2nd goes the slowest, although it's still a little too fast for ag purposes IMO, of course this isn't actually an ag tractor though. Any chance there's a way to slow it down? I like to have a 1 low that really crawls for working in tight spots.
   / 4600 Reverse in 3rd gear position. #4
see.. that's exactly why i asked.
most people see a twin stick and assume an 8spd.
you have the 6x4
you are pretty much stuck with what you got.... slow it down? sure.. smaller wheels n tires. :) or a different machine...
   / 4600 Reverse in 3rd gear position. #5
Also, the CU212K designates the 335 model which someone could have put in a 4600. The 4600 had more Hp. To see if it is a 4600 engine look at the S/N stamped on the top of the oil pan on the right side. K indicates the 201 engine like a 4600.
   / 4600 Reverse in 3rd gear position. #6
201's are nice and throaty!
   / 4600 Reverse in 3rd gear position. #8
Yup, like a 3600, etc
   / 4600 Reverse in 3rd gear position. #10
The transmission is in the 3600 or 335 transmission section, 6x4. Those stabilizers will work, but may need to do a little modification lift arm bolts.
377811 (A48836)
377811 (A48836)
2007 FELLA SM350 3 PT DISC MOWER (A52748)
2007 FELLA SM350 3...
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
20306 (A51694)
20306 (A51694)
NEW Wolverine Skid Steer Pallet Forks Hydro Adjustable (A53002)
NEW Wolverine Skid...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
