4600 Reverse in 3rd gear position.
   / 4600 Reverse in 3rd gear position. #1
petebert
Outside of Ann Arbor
If we think of the shifter as
A B C
D E
I'm getting reverse in D and E, also 1 low isn't any slower than 2 low.
   / 4600 Reverse in 3rd gear position. #2
What transmission do you have.. Post the model I'd #.
Twin stick,right?
Yes twin stick, which serial do you need? The transmission case is stamped D5-NN-7006 P
I think this is what you need more, looks like the model is CU212K, transmission is 8023C
Did some googling, it appears that this "4600" would be a 335 that somebody put a lot of effort of dressing up as a 4600. Also found the gear chart below, explains why what I thought was 2nd goes the slowest, although it's still a little too fast for ag purposes IMO, of course this isn't actually an ag tractor though. Any chance there's a way to slow it down? I like to have a 1 low that really crawls for working in tight spots.
   / 4600 Reverse in 3rd gear position. #4
see.. that's exactly why i asked.
most people see a twin stick and assume an 8spd.
you have the 6x4
you are pretty much stuck with what you got.... slow it down? sure.. smaller wheels n tires. :) or a different machine...
   / 4600 Reverse in 3rd gear position. #5
Also, the CU212K designates the 335 model which someone could have put in a 4600. The 4600 had more Hp. To see if it is a 4600 engine look at the S/N stamped on the top of the oil pan on the right side. K indicates the 201 engine like a 4600.
   / 4600 Reverse in 3rd gear position. #6
201's are nice and throaty!
   / 4600 Reverse in 3rd gear position. #8
Yup, like a 3600, etc
   / 4600 Reverse in 3rd gear position. #10
The transmission is in the 3600 or 335 transmission section, 6x4. Those stabilizers will work, but may need to do a little modification lift arm bolts.
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
1266 (A50490)
1266 (A50490)
2011 Ford Crown Victoria Passenger Car (A51694)
2011 Ford Crown...
2019 CHEVROLET SILVERADO 1500 (A52472)
2019 CHEVROLET...
2018 FORD F-450 XL FLATBED TRUCK (A51406)
2018 FORD F-450 XL...
