4600 Reverse in 3rd gear position.
   / 4600 Reverse in 3rd gear position. #1
petebert
Outside of Ann Arbor
If we think of the shifter as
A B C
D E
I'm getting reverse in D and E, also 1 low isn't any slower than 2 low.
   / 4600 Reverse in 3rd gear position. #2
What transmission do you have.. Post the model I'd #.
Twin stick,right?
Yes twin stick, which serial do you need? The transmission case is stamped D5-NN-7006 P
I think this is what you need more, looks like the model is CU212K, transmission is 8023C
Did some googling, it appears that this "4600" would be a 335 that somebody put a lot of effort of dressing up as a 4600. Also found the gear chart below, explains why what I thought was 2nd goes the slowest, although it's still a little too fast for ag purposes IMO, of course this isn't actually an ag tractor though. Any chance there's a way to slow it down? I like to have a 1 low that really crawls for working in tight spots.
   / 4600 Reverse in 3rd gear position. #4
see.. that's exactly why i asked.
most people see a twin stick and assume an 8spd.
you have the 6x4
you are pretty much stuck with what you got.... slow it down? sure.. smaller wheels n tires. :) or a different machine...
   / 4600 Reverse in 3rd gear position. #5
Also, the CU212K designates the 335 model which someone could have put in a 4600. The 4600 had more Hp. To see if it is a 4600 engine look at the S/N stamped on the top of the oil pan on the right side. K indicates the 201 engine like a 4600.
   / 4600 Reverse in 3rd gear position. #6
201's are nice and throaty!
   / 4600 Reverse in 3rd gear position. #8
Yup, like a 3600, etc
   / 4600 Reverse in 3rd gear position. #10
The transmission is in the 3600 or 335 transmission section, 6x4. Those stabilizers will work, but may need to do a little modification lift arm bolts.
2018 POLARIS RANGER 570 EFI UTV (A51247)
2018 POLARIS...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
2019 FORD F-250 (A52472)
2019 FORD F-250...
2007 CHEVROLET BUCKET TRUCK (A52472)
2007 CHEVROLET...
New/Unused 7ft 10 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 10...
2019 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
