455 hydraulic leaks
/ 455 hydraulic leaks #1
ashurd455
Purcellville, VA
Hello all,
New here, so thanks in advance for your help. I have a 455 that I love with a 60 deck and only 1200 hours on it. Last fall it began to leak a little from the rear differential, now it's quite a bit. I have to add a little fluid after about 8 hours of use and leaves a decent mark on the garage floor. Any thoughts? Do I need to be concerned about the actual transmission being damaged? I've never let the fluid get too low. Any suggestions on how to repair?
Thank you!
/ 455 hydraulic leaks #2
:welcome: to TBN
Have you removed the fender deck to learn more about where the leak is coming from? Pics will help if diagnosis is needed.
A drain pan under it when parked will help determine how much leaks when not running vs. leakage when operating.
:welcome: to TBN
I have not removed anything yet. I will run tests and post photos shortly.
Thanks,
