455 hydraulic leaks
/ 455 hydraulic leaks #1
ashurd455
Purcellville, VA
Hello all,
New here, so thanks in advance for your help. I have a 455 that I love with a 60 deck and only 1200 hours on it. Last fall it began to leak a little from the rear differential, now it's quite a bit. I have to add a little fluid after about 8 hours of use and leaves a decent mark on the garage floor. Any thoughts? Do I need to be concerned about the actual transmission being damaged? I've never let the fluid get too low. Any suggestions on how to repair?
Thank you!
/ 455 hydraulic leaks #2
:welcome: to TBN
Have you removed the fender deck to learn more about where the leak is coming from? Pics will help if diagnosis is needed.
A drain pan under it when parked will help determine how much leaks when not running vs. leakage when operating.
:welcome: to TBN
I have not removed anything yet. I will run tests and post photos shortly.
Thanks,
UNUSED WOLVERINE TF1-66-4000G-66" PALLET FORKS (A62131)
UNUSED WOLVERINE...
2015 CATERPILLAR 259D SKID STEER (A62129)
2015 CATERPILLAR...
UNUSED WOLVERINE QC1-26-20G UNIVERSAL HITCH (A62131)
UNUSED WOLVERINE...
2019 ISUZU MPR HD 18' BOX REEFER TRUCK (A62130)
2019 ISUZU MPR HD...
2014 FREIGHTLINER SPRINTER 2500 4X2 CARGO VAN (A59909)
2014 FREIGHTLINER...
2017 FORD F-450 XL BUCKET TRUCK (A58375)
2017 FORD F-450 XL...
