Mowing 455 54 inch deck problem
/ 455 54 inch deck problem #1
BrisMatt
Australia
JD 455
Hi, I have a JD 455 which has lost all power at the cutting deck. When I engage the PTO switch the deck barely spins (i mean barely) and you can stop it by putting your foot on one of the pulleys.
I know this machine has a combined hydraulic system, the one pump runs the drive, the steering, the deck lift and the PTO, and all the things except the PTO work fine, so I am fairly confident its not a dodgy pump or something as bad or expensive as that.
Does anyone have any ideas? I thought it may be the solenoid located on the back of the transmission case but Im not sure how to test it.
Thanks
Matt
/ 455 54 inch deck problem #2
I would start with the easy stuff. Is your belt OK that runs the deck and no idler pulleys froze up?
/ 455 54 inch deck problem #3
Sounds like it would be the belt on the mower deck. Look at it before getting a new belt. Could have slipped off a pulley or the spring may have come off/broke. Look at the PTO shaft that goes to the mower deck and make sure it's turning like it should. Dan
Went and had another look yesturday and it is definately a mid PTO issue, not a problem with the deck. The manual has some ideas which I will try out over the weekend.
/ 455 54 inch deck problem #5
Sounds like adjustment of the mid-pto clutch/brake.
Do you have the tech manual?
Here is a chart of 4 tests leading to other tests.
/ 455 54 inch deck problem #6
I just read about a similar problem, but
on this one they noticed a lot of heat
on the transmission, turned out to be
a faulty pto brake problem.
(hanging up)
another option to investigate
