Ballast 4530 Pick Up Levers Question
/ 4530 Pick Up Levers Question #1
Blaze08
Ga
Mahindra 4530/Ford 4610
Over time my pick up levers on the right, (to pick up 3 pt in back) will barely move. It's a huge pain to bush hog and not be able to easily pick up the Bush hog. Just checking to see if there are actual grease fittings or anything on there? Thanks
/ 4530 Pick Up Levers Question #2
From what I remember this issue has been solved by cleaning the linkage and your favorite spray lube. I believe their are other posts on the subject. It’s not called the pickup lever though.
Thanks, what is it called then? My mind went blank.
/ 4530 Pick Up Levers Question #5
He Referring to the lever that operates the 3 point so 3 point lever would be the proper terminology.
I don稚 know about his model but mine has grease zerks on the lever pivot points.
/ 4530 Pick Up Levers Question #6
Sorry if I came across wrong. Just wanted you to have some luck if you were to do a word search. Looks like you got good answers to the name. 3 point lever would work. Draft control may work but some will have a narrower definition of draft control so that can be hit and miss. Good luck and let us know if you need anything else.
iDrive TDS-2010H...
2005 Great Dane Dry Van Trailer, VIN # 1GRAA56185K270688 (A61165)
2005 Great Dane...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2012 Ford Expedition SUV (A61574)
2012 Ford...
2023 CATERPILLAR 326 LONG REACH EXCAVATOR (A62129)
2023 CATERPILLAR...
1998 Mack DM690SX Chassis Truck  (A62679)
1998 Mack DM690SX...
