4530 hydraulic tank
/ 4530 hydraulic tank #1
Latheman
does anyone know the capacity of the hydraulic tank on these tractors? /forums/images/graemlins/confused.gif I friend of mine is looking to put a woods backhoe on his and was trying to figure if he should go with the pump kit or not. I know that the 4500 have such a small tank that they tend to over heat when using a backhoe, but can not find info to tell me if this is also true with the 4530. I am guess that it will be since they look so similar.
Thanks,
/ 4530 hydraulic tank #2
The 4530 has integrated hydraulics, unlike the 4500, meaning that the trans, rearend and hydraulics share fluid. You won't need a tank. On the 4500, the hydraulic capacity is much smaller and a tank is needed for a backhoe.
/ 4530 hydraulic tank #3
Dave:
Does the power stearing also share the same hydraulics? Is there just one drain plug and filter for the entire hydraulic system and how many gallons does the system hold?
I am considering replacing my old tractor, and the 4530 looks like a good tractor. Thanks for any info you can share on the 4530.
2021 KENWORTH T680 6X4 T/A  SLEEPER TRUCK TRACTOR (A59914)
2021 KENWORTH T680...
2022 EZ-GO ELITE...
McCormick X6.55 (A64126)
McCormick X6.55...
John Deere 1530 Tractor (A66285)
John Deere 1530...
New/Unused ATS Plasma Cutter (A65583)
New/Unused ATS...
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
