Mowing 4520 pto
/ 4520 pto #1
lembachf
my 4520 ran fine for the last 3 years and now warranty is up (4 months ago) now its time for brush hogging. wouldn't you know when the brush hog is raised pto works fine. then i lower the brushhog and start moving my pto stops.... why is that. the dealer wants 80 bucks an hour to trouble shoot. i pulled my cluch on the brush hog no problems there so it has to be my tractor. any ideas or waste 80 bucks
/ 4520 pto #2
First welcometo the forum.:D
How much use has the tractor had with pto work? A better description would help too. Does the pto light or display remain on or does this turn off too? If the mower is lowered and turning does it fail in heavy grass or brush or simply anytime the tractor movement is engaged?
A service manual on CD is about $75 might be good to have, I need to remember to get one myself.:ashamed:
If the pto stops in heavy use it most likely is a slipping clutch, a good tech should be able to determine the problem in short order.
I would not consider the $80/hr to be a waste of money, everybody has to make a living. Understand how you feel though, I wouldn't want to see a pto failure this early either.
/ 4520 pto #3
May be in one of the safety circuits, if I read right, the problem is the PTO cuts off when the machine starts to move, this being the case, I would look into the safety switches; there should be a section in the operators manual on how to check the safety switches that are on the machine. If you don't have or can't find the operators manual, there should be an online version on the JD website.
12V YARD SPRAYER (A64278)
12V YARD SPRAYER...
Swict 78in Bucket Skid Steer Attachment (A64553)
Swict 78in Bucket...
TRIP HOPPER JR CUBE / CAKE FEEDER (A64278)
TRIP HOPPER JR...
1997 Volvo WG Day Cab Truck Tractor (A64194)
1997 Volvo WG Day...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2019 Ford F-150...
2022 EZ-GO ELITE...
