4500 question
/ 4500 question #1
fish_wisperer
Banned
east of dallas
mahindra 4500 2wd
sometimes when i go to engage pto it wont go, the shifter wont go back, i let off clutch, put it in and out of gear, push clutch back in, then try again and it works, sometimes i have to do this a couple times. it seems like it just has to syncronize. is this a problem?
/ 4500 question
also sometimes when i go to take it out of gear its kinda hard to pull out and you can feel a little fwd pressure release when it comes out, maybe clutch needs adjusting? it dosnt happen all the time and doesnt grind putting it into gear unless i get into a hurry and dont give it time to syncronize.
/ 4500 question #3
You should almost have 1 inch of "play" at the end of the clutch travel. Sounds like you need to check your clutch adjustment to me. I don't ever have to "wait" for it to synchronize. As far as the PTO lever, likely an adustment needed. BobG in VA
/ 4500 question #4
I have never been on a tractor (most of our stuff is NOT late model) that I didn't sometimes need to "roll" the tranny a bit to engage/disengage the PTO. Sometimes all those gears just get in a bind and the pressure needs to be relieved for them to mesh/unmesh. I would rather roll the tranny a bit than bend/break a lever or acutator fork inside.
2022 EZ-GO ELITE...
4" Hydraulic Pump (A64127)
4" Hydraulic Pump...
2009 VOLVO VHD BOBTAIL VACUUM TRUCK (A65643)
2009 VOLVO VHD...
IRRIGATION PIPE FITTINGS (A64276)
IRRIGATION PIPE...
2021 Ford Transit 350 HD Reefer Box Van (A64194)
2021 Ford Transit...
John Deere Lift Arms (A65640)
John Deere Lift...
