4500 question
/ 4500 question #1
fish_wisperer
Banned
east of dallas
mahindra 4500 2wd
sometimes when i go to engage pto it wont go, the shifter wont go back, i let off clutch, put it in and out of gear, push clutch back in, then try again and it works, sometimes i have to do this a couple times. it seems like it just has to syncronize. is this a problem?
/ 4500 question
also sometimes when i go to take it out of gear its kinda hard to pull out and you can feel a little fwd pressure release when it comes out, maybe clutch needs adjusting? it dosnt happen all the time and doesnt grind putting it into gear unless i get into a hurry and dont give it time to syncronize.
/ 4500 question #3
You should almost have 1 inch of "play" at the end of the clutch travel. Sounds like you need to check your clutch adjustment to me. I don't ever have to "wait" for it to synchronize. As far as the PTO lever, likely an adustment needed. BobG in VA
/ 4500 question #4
I have never been on a tractor (most of our stuff is NOT late model) that I didn't sometimes need to "roll" the tranny a bit to engage/disengage the PTO. Sometimes all those gears just get in a bind and the pressure needs to be relieved for them to mesh/unmesh. I would rather roll the tranny a bit than bend/break a lever or acutator fork inside.
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
2007 Great Dane 53' Reefer Trailer (A64127)
2007 Great Dane...
Snap-On Zeus Diagnostic Machine (A63689)
Snap-On Zeus...
2020 International LT625 Sleeper 48" (A62613)
2020 International...
1999 Sterling Dump Truck (A66285)
1999 Sterling Dump...
1996 International 4700 (A64127)
1996 International...
