4500 fuel problem
/ 4500 fuel problem #1
chuck diesel
SE Michigan
'99 JD 4600, 460 fel
My dad was using his brush hog for about 2 hrs. Stopped for about 15 min. Tried to start mowing again, CLICK.
He has had this problem before. He let it sit over night and started right up the next day.
Any suggestions?
Thank You
Chuck D.
/ 4500 fuel problem #2
Check and clean all 4 battery cable connections. Check battery voltage with a volt/ohm meter if a battery tester is unavailable
/ 4500 fuel problem #3
Yep, I'd put my money on battery and/or connections. Do as Jim says above and go from there.
/ 4500 fuel problem #4
Click?
Is that the fuel solenoid pulling in or the starter engaging? Does the 4500 have the same thermistor as its little brothers, 4400, 4300?
A failed or failing thermistor will allow the starter to engage and spin the engine but will not allow fuel to the injection pump. It can be temprature related too.
If the battery or cables don't get you going keep this in mind.
Best, Alan
/ 4500 fuel problem
That's funny about the pto knob. From what i hear the fuel solenoid is not pulling in.
Chuck D.
/ 4500 fuel problem #7
Chuck D.
I could not tell from your original post if it was cranking and not starting, or, not cranking at all.
"My dad was using his brush hog for about 2 hrs. Stopped for about 15 min. Tried to start mowing again, CLICK.
Any suggestions?
Thank You
Chuck D."
2006 Heil DOT 406 Comp Fuel Tanker (A64194)
2006 Heil DOT 406...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
PIPEHUNTER HYDRO EXCAVATION TRAILER (A65643)
PIPEHUNTER HYDRO...
2025 24in Mini Excavator Bucket Attachment (A64553)
2025 24in Mini...
2016 Ford Expedition SUV (A64557)
2016 Ford...
