445 Battery Light On
/ 445 Battery Light On #21
From TM1517:
On the 445
From the manual page number 5-184:
1st paragraph, 3rd and 4th sentence:
A discharge light (H3) warns the operator if the stator stops charging. The discharge light circuit monitors stator output, not battery voltage.
4th paragraph:
If the stator output current to the rectifier/regulator stops, the rectifier/regulator provides current to the discharge light (H3) to light the lamp.
Follow test procedures:
So check output voltage (AC voltage (minimum is 26 VAC) and current from stator!
Current output from regulator 13A
Well this may be way out there, but I suppose it's possible that you are getting a lot of AC across the battery terminals from the alternator. Battery's don't like AC...
Richard
I have ordered a new VR to try. The AM126304 is $69.50 GFP online.
Stens aftermarket has # 435 180 for $26.99.
I will try one of these cheap deals.
I will check the voltage & DC current details before & after I replace the VR.
I know that diodes can fail & you get some AC voltage on the battery.
I'm not sure how a VR works. Maybe large zener diodes?
I think the input is ~ 26 VAC from the sensor.
So it has to convert this to DC, so it's can't be just a full wave bridge.
Thanks for mentioning this as a possibility.
It will be about a week before I get the new VR.
I know this thread is old, but I need to post this info.
I did not mention here another symptom.
It was also fouling the left plug about every 4 hours.
1300+ hrs on the machine & at ~1000 hrs I replaced the rings.
So I expected the left piston was just worn too much. (It was not bored)
But after all this & replacing the V Regulator I got a surprise.
I have used the mower now for about 30 hours without fouling that plug.
So... whatever that semi/intermittently-bad VR was doing was fouling the plug.
I have 5 JD mowers now, including an almost new X540 and this 445 mower is still my favorite.
NISSAN 35 MAST FORKLIFT (A67714)
NISSAN 35 MAST...
2012 KOALA BUMPER PULL (A67714)
2012 KOALA BUMPER...
2015 KUBOTA F3990 MOWER (A66091)
2015 KUBOTA F3990...
2012 COMPTANK CORP. 130BBL FIBERGLASS ACID TRAILER (A67714)
2012 COMPTANK...
2007 INTERNATIONAL 7600 6X4 T/A GARBAGE TRUCK (A66091)
2007 INTERNATIONAL...
Frontier Forks (A64911)
Frontier Forks...
