4430 steering question
/ 4430 steering question #1
kevlar
Clanwilliam,MB
John deere
Hi I'm new here and need some help. I have 4430 that was leaking oil from the steering column. Took it apart and it has a fairly large steering control valve on the end of the column. Took it to a John deere dealer and they said it would take about 8 hours to rebuild it and that it was fairly difficult to get all the adjustments set. So I tried a wrecker to see if I could get a used one. (because 8 hours at $120/hr, ouch!!) I got one but it is just a small valve about 8 inches by 5 inches by 3 inches thick. I put it in but have absolutely no steering at all now!!! I'm wondering if the new valve will work on this type of tractor or am I missing anything? I've looked around and noticed some discussions mention a metering valve under the hood, pretty sure there isn't one this tractor. Please help!!!! I need it to push snow and it keeps snowing every day!!!!!
/ 4430 steering question #2
It's been since late 80's since I was a JD dealer service manager but 8 hrs to reseal & adjust a steering valve laying on the bench sounds way to much time spent drinking coffee and eating cookies by mechanic. Steering valve in parts photo(metering pump style) will not work on a 4430 before serial number 027635. I just talked on the phone to a JD technician in Somerset,Ohio named Tim that stated that the seal kit was $100 plus $200 labor plus shipping he could disassemble,re-seal,adjust valves and test for correct operation & leaks. If you would like his contact information contact me by way of private messaging. He built a test stand with a hyd pump to test JD closed center hyd components that I wish I had access to back when I was a JD dealer service manager. HE"S GOOD on JD's.
Thanks Tx Jim. I thought that was too much time also. The picture you have is the one I put in. The old one was much bigger. Guess I will have to put the old one back in for the time being. Just went from a slow messy leak to no steering at all so slow leak is better! Do you know if I can make that type of valve work with modifications to the tractor?
/ 4430 steering question #4
To make the newer style valve work on your tractor you would have to also change these steering components plus some lines. You'd be better off to have your old valve resealed and adjusted by a qualified technician.
That's kind of what I was thinking. Thanks so much for all your help. Wish I had talked to you sooner!
/ 4430 steering question #6
The technician I talked to in Ohio told me he had a man from Tx(not me) ship him for reseal a steering valve in a 5 gal. oil bucket with a hole cut in the top for the shaft. He stated he resealed,adjusted,tested valve and shipped it back to Tx and freight was $45. Here's a couple of photo's of Tim's hyd testing bench he posted on another forum. After he tests it he knows there's no hyd leaks and it works before installation. It would have saved me a lot of gray hairs back when I was a JD service man. if I had access to a test bench such as the one in the photo's
/ 4430 steering question #7
Tx Jim I have somewhat of a similar issue, I have an early model John Deere 4430 cab tractor 2wd (has the narrow seat well) and the steering it is now wandering going down the road. I "think" the tie roads are ok. I have noticed a little hydraulic fluid leak under the dash that runs down near clutch and brake pedals AND I notice a hydraulic leak up toward the front of the tractor as well, sometimes it's pretty bad, sometimes not hardly any? Any ideas? I'm afraid it may need to steering motor and steering valves rebuilt? If so any help on the process of doing that and then getting it to someone reasonable to fix it, we are pretty good mechanics, but looks like the steering valve at least needs a professional to reseal and calibrate it, like Tim possibly as you referred to above? What about the steering motor, can we fix it or does that need a professional to rebuild and calibrate it as well? Local dealer isn't very helpful unfortunately...allen@tennesseeland.com
/ 4430 steering question #8
The steering motor can be resealed in the tractor. One just needs to have tractor supported sufficiently so as no one gets hurt or killed because a side rail must be removed to access a side plug. The reason I'd recommend Tim to reseal & calibrate the steering valve is the fact that as far as I know he's the only person that can bench test the valve & as you'll find out the valve is no fun job to R&R.
/ 4430 steering question #9
Thank you. Is there a link somewhere or something for an instruction sheet as to how to remove the valve and a sheet for how to get to and reseal the motor?
/ 4430 steering question #10
The instructions for resealing steering motor are in a JD 4430 technical manual
/ 4430 steering question #11
OK, I don't have one, but thanks however...
I see: "John Deere 4430 I&T Aftermarket Shop Repair Manual" for sale on internet for about $27.00, do you think it would have the info in there?
/ 4430 steering question #12
Also, when I get steering valve off how do I contact Tim? Or you could direct him to my email address I have including in previous post? THANKS!
/ 4430 steering question #13
Tim's phone # is 7four0-7four3-1zero8five. I&T manuals aren't near as informative as the JD TM.
/ 4430 steering question #14
You may want to look at selectmanuals.com for TM1057 it is downloadable for $39.95.
Let us know how things turn out for you on your repairs.
/ 4430 steering question #15
THANKS! Will check that out!
/ 4430 steering question #16
If you want the manual for your John Deere 4430 but dont want to wait you can get it online
and download it instantly to your computer.
/ 4430 steering question #18
Thanks! I will check that out. My early model 4430 cab tractor is bad to wander a LOT going down the road amd the tie rods, etc. are tight! It sure has something going wrong, been dealing with it for a while and gradually getting worse... Need more help and advice...
/ 4430 steering question #19
Still dealing with the same problem after 4 years? or a new one?
/ 4430 steering question #20
same... Wasn't as bad, but getting worse, local John Deere dealer not much help on older tractors seems like either...
