4410 Throttle
/ 4410 Throttle #1
cef2lion
Central PA
JD 4410, JD455
The throttle on my 4410 hydro slips back after I set the RPMs. Talked to the dealer and they said it is a common adjustment they make. There is a bolt that needs tightened. They offered to come out but it would be a week or so. Was getting tired holding the lever to mow. I fixed it yesterday. You need to pull the plastic cover around the fuse panel. Then you need to takes all the bolts out for the side panel next to the key. You also need to take the bolts out of the top panel around the gauges. You lift that and the side panel works off. You do need to take the knob off the locking brake as well. Bolt is 13mm and I tightened it half a turn. Throttle is holding now.
Craig
Extra note. Some of the bolts you take out have a washer back behind. I found out when I pulled one bolt and the washer dropped. I got my hand behind on the rest.
/ 4410 Throttle #2
And what do you do with the extra parts? /forums/images/graemlins/shocked.gif
/ 4410 Throttle #3
I have had the identical problem with my 4200. However, I was able to solve it by only removing the two bolts holding the instrument panel, pulling the panel out and then using long combination wrenches reach through to the throttle linkage and tighten the nut while holding the bolt. Sounds like the same solution but with less disassembly.
Bill
John Deere Front & Rear Rims (A64119)
John Deere Front &...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
2022 BOBCAT T870 SKID STEER (A64279)
2022 BOBCAT T870...
1998 FAST CRAFT 14' FIBERGLASS BOAT (A63291)
1998 FAST CRAFT...
UNUSED WOLVERINE HYD TILLER (A64281)
UNUSED WOLVERINE...
2004 Rogers Detach Lowboy, 28' Well, Tandem Axel (A62679)
2004 Rogers Detach...
