4410 Loader and Mower
/ 4410 Loader and Mower #1
Anonymous Poster
Epic Contributor
The loader sure is easy to take off and put on. The mower is easy but not as easy. Don't need any tools for either.
Time for the loader is 3:15 including caping the hyd.
Time for the mower is 9:15
The times will improve with experiance.
How often do you plan to remove the MMM? Also, what's the blue thing in the foreground of the picture?
I don't plan on taking the MMM off as much as I do the loader. The wife will be using this to mow with (and the 345) whem I'm out of town. The blue thing is a hyd jack I used to lift the deck after I moved it out from under the tractor. Its unbelievably heavy. The only way I'm going to get to the blades on this thing is by using the loader to stand it up.
/ 4410 Loader and Mower #4
jimmo, Your picture is hard to see back of tractor. Do you have a top & tilt? It looks like hydraulic lines looped around back there.
Yes, that is top&tilt. Here is a little bit better pic. (still not very good)
/ 4410 Loader and Mower #6
Great pics! Super looking place, and not a half bad tractor setup...
Do you have any more pics of the top-n-tilt that show the control, etc? I am thinking that it would be a nice addition to mine, just curious as to the setup....
From All the Way to Oklahoma... /forums/images/graemlins/laugh.gif
/ 4410 Loader and Mower #7
Jimmo, Thanks. I have a 4400 w/ 3rd, 4th. 5th, remotes and thinking about T&T. Use a quick hitch so don't know if it is worth it. Seriesly concidering 4in1 bucket. MMM is easy on-off, just a little longer time on ground verses concrete.
/ 4410 Loader and Mower #8
Great looking setup! I've had my 4310 for almost 1 year and have never taken the loader off... it's funny because one of the things I liked about JD was how quickly you can change attachments! /forums/images/graemlins/tongue.gif
I have taken the Backhoe off twice and it is getting faster each time but I have not come close to the 5 minutes they claim /forums/images/graemlins/confused.gif... I'm sure with experience I will /forums/images/graemlins/grin.gif
/ 4410 Loader and Mower #9
Very nice! could you take several pic of your 4 in 1 bucket? I would like to build one some day.
/ 4410 Loader and Mower #10
I have the quick hitch (I-match), and if I also had the top-n-tilt, I would then fix my forks to also quicktach to the 3pt. I think this would be a handy tool (forks on the back as well as be able to use them on the loader). I could then stack more firewood on the pallets if they were carried on the 3pt, I think.
/ 4410 Loader and Mower #11
Nice setup, I have the std bucket at the moment, 4-1 is down the list of things to get.
Your tires look larger than mine, did you get the oversized ones? I was advised by the dealer that the MMM will hit (or come awlfully close) to the larger tires. Just a thing to watch.
I usually take my time removing the attachments, I always seem to double check or I forget the sequence of things.
This tractor make a hell of a lawn mower /forums/images/graemlins/grin.gif . For deeper grass, flip up the deflector so the cut grass does not build up and you can really move. Just watch for rocks and other debris so you don't hit anyone or thing.
/ 4410 Loader and Mower #12
Jimmo, Would like to see some 4 in 1 pictures as to how the two halves of the bucket come together. I am thinking of buying one. Have heard of edges of bucket bending if you clamp too hard trying to hold, say a tree in the bucket.
Sorry I can't send any pics of the 4in1 bucket as I've still got a week till I get back to MO. I'll take some pics then.
When I got the tractor the dealer had the tires loaded because of the FEL which I thought was a good thing. As it turns out I decided after 1 day that loaded tires are not good for mowing. Just too much compaction. After I drained the tires through the valve stem I laid them over and the bead broke and the left over water/alcohol drained out. Used a chinch strap around the tire to set the bead and after 15 minutes of pumping with my 12 volt pump I was back in business.
As far as I know the tires are standard size. Also the dealer said there was no "stance" diferance when mounting the tires. I measured the hub to rim size and there is a 2.5 inch diferance. So I mounted the tires on the other side for a wider stance. The only drawback to this is the valve stem is on the inside. There was a question about weather this would work with the 72 in MMM. There is no problem, plenty of clearance. I mowed the 6 acre pasture just to make sure. Great mowing machine.
I supose a ballast box and air compressor are next.
FIRD MIXER TRUCK (INOPERABLE) (A67714)
FIRD MIXER TRUCK...
INGERSOLL RAND BLAW-KNOX PAVER (A67714)
INGERSOLL RAND...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
2012 RAM 4500 (INOPERABLE) (A67714)
2012 RAM 4500...
2006 LeeBoy L8510R Low Deck Asphalt Crawler Paver (A66734)
2006 LeeBoy L8510R...
