4410 John Deere No Start
   / 4410 John Deere No Start #1
2diamondfarm
Bronze Member
West Michigan
TYM 574, Deere 4410, Gehl 353 Mini Ex
My JD 4410 has a problem engaging the starter when the key is turned .
I believe it has something to do with the neutral switch because I have to move the shifter around and find just the right spot while turning the key to get it to engage the
starter
Outside temperature doesn't make a difference .
I have tried by passing the neutral relay in the fuse block with no results.
the seat switch is already by passed . I would like to total bypass the neutral switch if that is possible .
I am open to any ideas
   / 4410 John Deere No Start #2
Bi-passing relay has not effect on the worn neutral switch. You must bi-pass the switch. Having said that,I don't recommend bi-passing any type safety devices unless I know every operator like a brother. There's someone killed or crippled every day as the result of disabled safety devices. Just replace the switch,it might save a life in the future. If neutral switch can't be replaced,bi-pass it but reconnect seat switch to prevent starting from the ground. I KNOW,you never start your tractor from the ground but someone else might. The seat switch is a little help in preventing a child that is climbing on tractor hitting starter.
Thank you for your concern but right now I just need it to start! right now when I need it
   / 4410 John Deere No Start #4
   / 4410 John Deere No Start #6
I think I have found it but it is right up tight to the floor board . I think I will have to remove it to get to it.
Just pull the wire plug and bridge it across the 2 terminals with a piece of wire.
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A55315)
2003 International...
2013 Dodge Durango (A53317)
2013 Dodge Durango...
John Deere 5055E (A53317)
John Deere 5055E...
2020 DRAGON ESP...
2018 HINO CONVENTIONAL TYPE TRUCK (A58214)
2018 HINO...
2019 Harley Davidson (A56859)
2019 Harley...
